Would I be better on Pro
- Would I be better on Pro
04-02-2009 3:23 PM
Re: Would I be better on Pro
04-02-2009 3:25 PM
04-02-2009 3:26 PM
Even downloading a trial of Office 2007 it was hitting over 100 kB/sec in early evening on Monday
04-02-2009 3:27 PM
The only issue I had was slow PSN downloads, but I can live with that for a bit..
04-02-2009 3:38 PM
Anyway as cancellations tell me I cant get a MAC unless I pay up for both home phone and BB and then head back to errr, BT (want to keep HP and pay off the ADSL) I cant do diddly squat till September so am looking at whether to cough up the extra and go Pro so am not throttled.
Is it worth it?
04-02-2009 3:40 PM
Quote from: newmillscomp Quite the opposite - unusable after 4pm
On PAYG (same priorities as Pro) I've seen no problems - I wonder if the problem is your exchange and nothing to do with Plusnet.
04-02-2009 3:41 PM
If you can give links to some of the sites you have problems with and we can check how it works for us.
04-02-2009 3:46 PM
04-02-2009 3:51 PM
You weren't on Pro & had a BT issue at either the exchange or on your line.
04-02-2009 3:52 PM
Quote from: techguy I request a downgrade to option 1 with a view to leaving last night is it likely I'll cause issues if I put in another request?
If you call CS, they'll be able to cancel one downgrade and apply the upgrade for you.
04-02-2009 3:54 PM
04-02-2009 3:56 PM
04-02-2009 3:57 PM
04-02-2009 4:00 PM
Anyway, tis done now and I'll stick with this as at least my packets will be able to queue jump now.
Yes James think it is
04-02-2009 4:05 PM
