Worth turning Interleaving off?
- Worth turning Interleaving off?
11-05-2010 10:25 PM
A little advice please, basically, i do alot of gaming, and want my pings down a bit but when interleaving was off before it caused all sorts of sync problems, down to other previously undetected faults on the line that basically came to a head last week and have now been fixed, with my sync speed now being 1/3 faster than it has ever been before! suggesting that I have a very clean line (im syncing at 8039Kbps on a 42Db Attenuation!)
so i was wondering, based on these stats will Interleaving do any good, or will it just bring the problems back do you think?
Mode: G.DMT
Type: ANNEX_A
Status: Showtime
Downstream Upstream
Rate (Kbps): 8032 kbps 448 kbps
SNR Margin (dB): 6.5 14.0
Attenuation (dB): 42.0 23.0
Output Power (dBm): 20.0 12.5
Super Frames: 8034906 8034906
RS Correctable Errors: 4989 0
RS Uncorrectable Errors: 20611 0
HEC Errors: 20321 2
Total Cells: 192243104 99729102
Data Cells: 99152048 88306407
Bit Errors: 0 0
Mode: G.DMT
Type: ANNEX_A
Status: Showtime
Downstream Upstream
HEC Errors: 20321 2
Bit Errors: 0 0
Message 1 of 6
(1,093 Views)
5 REPLIES 5
Re: Worth turning Interleaving off?
12-05-2010 10:00 AM
We can always turn it off and see, and then turn it back on if you have problems?
Message 2 of 6
(602 Views)
12-05-2010 10:07 AM
Hi Mand, yeah thats probably the best way forward could you sort that for me please?
Message 3 of 6
(602 Views)
13-05-2010 10:16 AM
Mand - I turned Interleaving off from the Member Centre yesterday, but i dont seem to have any improvement in Ping's, can you check its actually off please?
Message 4 of 6
(602 Views)
13-05-2010 10:24 AM
Hi severedsolo,
I checked this earlier and it looks like it's still on. I've placed a manual order to remove it, that'll complete tomorrow morning for you.
Message 5 of 6
(602 Views)
13-05-2010 10:43 AM
thanks Matt, I appreciate it
Message 6 of 6
(602 Views)
