Worst day so far
- Worst day so far
Worst day so far
28-08-2013 11:40 PM
for being disconnected from the internet. It seemed like every hour, the connection had gone, and I had to go through all the steps to be reconnected again.
Completely fed up.
Completely fed up.
Message 1 of 6
(1,324 Views)
5 REPLIES 5
Re: Worst day so far
28-08-2013 11:45 PM
I'm really sorry to hear you're having such problems, Allie0923.
Can you explain what keeps happening? I understand you keep losing connection, does it do it on it's own?
I'd quite like to find out what's causing the disconnections so we can get that sorted out for you.
Message 2 of 6
(465 Views)
28-08-2013 11:58 PM
Hi Chris
Thank you for replying. I would have answered sooner, but I'd just been disconnected again.
It just stops on its own. I'll go to send an email, to find I can't send as connection is down. Or place a bid on ebay - same thing.
I really am fed up, as I've missed out on some ebay items I wanted today (ok I might have been outbid anyway, but I'd have liked a fighting chance!)
Thanks for your help.
Best wishes, Allie
Best wishes, Allie
Message 3 of 6
(465 Views)
29-08-2013 9:29 AM
Are you connecting over a wired or wireless connection?
Below is a graph of your recent connectivity;
<img src="http://community.plus.net/visualradius/generated/image13777639696554.png"/>
If the disconnections are not caused by yourself resetting the router then I'd suggest running through our faults wizard and we can take a closer look at this.
Message 4 of 6
(465 Views)
30-08-2013 12:49 AM
I've clicked the link on the faults wizard, and a ticket has been raised.
So far, only one disconnection today and that was about half an hour ago.
Sorry to say this, but I didn't have this problem with O2.
Message 5 of 6
(465 Views)
30-08-2013 10:57 AM
We've got your fault ticket, unfortunately faults can surface, our faults team have this in-hand and we'll make sure that we get this resolved ASAP for you.
Message 6 of 6
(465 Views)
