Worst ISP
HNKS
Worst ISP
Angry Sick and tired of seeing buffering whilst watching steams. Im getting 50MB apparently. Terrible service. Cant believe Im locked on for 18 months.
Mattz0r
Re: Worst ISP
Hey there HNKS,
Sorry to hear that you're having streaming problems Sad
Are you able to provide a little more information, such as the current speed you're achieving: http://speedtest.net (Select the server location as London, UK) and also if you're connected via ethernet or wireless.
This will allow us to help identify the cause of your issue and work out some resolution for you.
Regards,
Matt
Finguz
Re: Worst ISP
Stick with it HNKS, the Plusnet guys and gals are a great bunch and they'll sort it out for you once you give them some details  Cool
HNKS
Re: Worst ISP
On Speedtest.net its showing 47mb. Im using a wired connection yet it doesnt seem stable at all.
All4One
Re: Worst ISP
How old is your computer? Do you maintain it well?
CX
Re: Worst ISP
What anti-virus and/or firewall software are you using? Have you tried temporarily disabling the anti-virus whilst attempting to stream something.
Also, which streaming sites?
Re: Worst ISP
Hi HNKS,
Sorry to hear that you're having streaming issues.
You line certainly appears to be stable:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13679223086284.png"/>
Does this happen on more than one device?
Fixes: 10
Re: Worst ISP
What results do you get from the BBC iPlayer diagnostic test?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 166
Re: Worst ISP
If you continue to have issues then I'd strongly suggest opening a fault ticket as our faults team look into this issue without one.
 Chris Parr
 Plusnet Staff
