Woosh test
puddy
Woosh test
I logged a broadband fault, when I looked in on my question its said
"Woosh test confirms intermittent fault"
What is a woosh test?
Puddy
(account jillweekes)
8 REPLIES 8
jelv
Fixes: 10
Re: Woosh test
It was my impression that it was the sound a fault made immediately after it was submitted to BT by Plusnet - Woosh and it's reurned "no fault found". Wink
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bobpullen
Fixes: 330
Re: Woosh test
It's a copper line test that we're able to conduct using a diagnostic tool provided by BT Wholesale.
Edit: lol @jelv
James
Re: Woosh test
WOOOOOOOOOOOSSSSSSSSSHHHHHHHHHHHHH!
Woosh is the name of a suite of diagnostic tools that BT Wholesale supply us with.
Most common test is a "One Shot Check" which runs various diagnostics on lines, showing line stats, connection frequency, failed logins and so on.
Strat
Fixes: 565
Re: Woosh test
Woosh Attentuation Test
This test is one of a whole suite of tests no longer used for line qualification anymore, due to the variations caused by the various bits of ADSL hardware people use but still of significance. In particular the attenuation test looks at the quality of the line across the ADSL frequency range and measures how much of the signal actually reaches your house.
shutter
Fixes: 67
Re: Woosh test
Which begs the question..... why do it then?
James
Re: Woosh test
Nah, it's still used.  Well, the actual tests are, but it's a different suite.
We now use the faults diagnostics suite of the BT Wholesale site, which isn't called Woosh anymore, but it does the same thing.
Strat
Fixes: 565
Re: Woosh test
Quote from: shutter
Not my words Cry
puddy
Re: Woosh test
Thank you for all the info.
I asked because of a fault that I have rasied with F9 they said they had done a whoosh test and it shows " Woosh test confirms intermittent fault"
I take it I do have a fault.
puddy
