Woefully low speed
tooslow
Woefully low speed
Plusnet.
Just did a BT Speed Test and my download speed is 3.91 mbps.
My normal speed here is over 16mbps.
Please can you see what the problem is and fix it?
Thank you.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Woefully low speed
I can't see any issues with your line that would be causing those speeds.
Profile: WBC 160K - 24M No delay (INP 0) 3dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+)
Sync: 1279 (up) 19270 (down)
If the problems are continuing please report this to us at https://faults.plus.net
 Chris Parr
 Plusnet Staff
Fixes: 9
Are the slow speeds using a wired or wireless connection?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
