Woeful speeds all the time
- Woeful speeds all the time
28-06-2008 9:20 PM
for 2 days now ive had terrible speeds and i use the pc usually from 8pm - 5am time, most definately OFF peak hours.
the test results below are woeful but if im being honest most downloads dont get above 14kbps and uploads well i think the best at the moment is around the 15-17kbps
can someone please look into this? its never been like this before.
ADSL Guide Speed Test:
Speed Test Results
Date 28/06/08 21:15:27
Speed Down 127.31 Kbps ( 0.1 Mbps ) <---- never achieved that on any download
Speed Up 89.37 Kbps ( 0.1 Mbps ) <----- i wish!! lucky to get 1/10th of that
Port 8095
Server speedtest1.adslguide.org.uk
Link: http://www.thinkbroadband.com/speedtest/results/id/12146840682938292477.html
BT Speed Test:
cannot get it to work at all.
Speed Test Results
Port 8095
BT Speed Test:
Message 1 of 3
(969 Views)
2 REPLIES 2
Re: Woeful speeds all the time
28-06-2008 9:28 PM
you haven't exceeded your usage allowance have you
alternatively what are the synch speeds reported by your router and what does this link give https://portal.plus.net/my.html?action=data_transfer_speed
Message 2 of 3
(346 Views)
28-06-2008 9:44 PM
also 8pm 2000 hrs til 2400 is definitely not off peak
Message 3 of 3
(346 Views)
