turn on suggestions
Wirelss card upgrade
- Wirelss card upgrade
26-06-2015 4:45 PM
At present I have a G wireless card. Would I get any improvement in service with one of the newer N cards.
I don't generally have any problems and my speed is about 12m/s.
Re: Wirelss card upgrade
27-06-2015 9:42 AM
Wireless g is likely to be faster than your 12mb/s so you are unlikely to see any difference with wireless n, it'll only make the comms with the router faster and this isn't usually the slowest part of the network
28-06-2015 10:48 AM
Thanks for the info.
