Wireless routers in stock?
- Wireless routers in stock?
28-04-2008 1:52 PM
I have signed up to the gaming package with plusner.
I am moving from AOL and I am still waiting for the phone line to be activated.
I have read some posts on these forums about the free wireless routers being out of stock a lot.
If the router is not delivered before the switch I think I will be left without any connection. The BT 105 Voyager I am using is branded with AOL and is probably locked.
Does anybody know what the situation is with wirless routers being in stock. I will have to cancel the whole process if there is going to be a big delay.
Cheers,
Iain.
Cheers,
Iain.
Message 1 of 7
(1,654 Views)
6 REPLIES 6
Re: Wireless routers in stock?
28-04-2008 2:06 PM
Are these the posts you refer to? http://community.plus.net/forum/index.php/topic,60014.0.html
Message 2 of 7
(535 Views)
28-04-2008 2:22 PM
Thanks for the reply
That is one of them, yes. Seen more recent ones though.
Just a bit worried at being left with no Internet access.
I placed the order on tuesday I think and the tracker shows the hardware has not been ordered yet.
Does anybody know what the router actually is at the moment. I need to get a wireless adapter and it seems to be a good idea to match makes.
Cheers.
Cheers.
Message 3 of 7
(535 Views)
28-04-2008 3:28 PM
We're currently sending out DLink DSL2640B wireless routers and unless there's been a dramatic change in stock, we're all good for these.
I'll go and give your hardware order a prod.
Message 4 of 7
(535 Views)
28-04-2008 3:47 PM
Thanks for the quick response
Iain.
Iain.
Message 5 of 7
(535 Views)
30-04-2008 9:31 AM
My broadband service has been switched now and as I feared no modem.
The order has not even been processed yet according to the order tracker.
Luckly the AOL modem is not locked so I can use wired for the time being.
Not the end of the world but a little annoying.
Not a good start.
Iain.
Not a good start.
Iain.
Message 6 of 7
(535 Views)
30-04-2008 10:57 AM
The router just showed up.
Tip to anybody signed up and waiting for a modem, ignore the online order tracker, it seems to be a bit of a liar.
Made me look like an A-hole. Sorry about that.
Iain.
Iain.
Message 7 of 7
(535 Views)
