Wireless router recommendations?
- Re: Wireless router recommendations?
18-06-2014 1:29 PM
Anyone have any suggestions or good words for a DSL wireless router (FTTC with BTOR modem) around 40-50?
If I can get something with dual band, that would be good.
I've seen the TP link routers which look decent.
Cheers.
Cheers.
Message 1 of 2
(455 Views)
1 REPLY 1
18-06-2014 2:05 PM
I've just bought a TP-Link WDR3600. It has dual band and can either do 2.4Ghz and 5Ghz simultaneously, or you can combine the two for up to 600Mbps (I think) speeds. It also has built in Dynamic DNS ability, so if you're not on a static IP, you can sign up to a free dynamic DNS supplier and when the IP address changes, it automatically updates your supplier.
It does not have a modem though, and would require the BTOR modem to stay in place.
I've seen poor reviews about the TP-Link ones that have built in modems.
Message 2 of 2
(301 Views)
