Wireless network security
- Wireless network security
18-10-2007 1:06 AM
Watt is my MAC address on the Screen Shot, I knoe that the information is there, but where?
I got the Screen Shot by following the information that I got from PlusNet.
Finding MAC address
Clicking Start > Run
Typing cmd and clicking OK.
Now type ipconfig /all to find your MAC address.
[Edit]
The link to the router.
Re: Wireless network security
18-10-2007 1:15 AM
18-10-2007 1:29 AM
Quote from: Peter Physical Address is you MAC address.
Well I put that in to the router and it didn't like it!
18-10-2007 1:32 AM
If you are using an easily crackable security scheme such as none at all or WEP then an attacker can inject packets with your MAC address in them.
18-10-2007 1:42 AM
18-10-2007 1:58 AM
18-10-2007 2:19 AM
Quote from: axisofevil But note that restricting wifi access to a particular MAC address will not enhance your security by very much.
Well if I can get it to work it will be better than none!
I have the Firewall on plus Zone Alarm Firewall on as well
Quote from: spraxyt Did you enter it without punctuation?
Yes and the router locked me out! I had to do a router reboot.
18-10-2007 2:58 AM
[Edit]
Whoops thank you both of you for your help.
[Edit]
The router is on full stealth plus Zone Alarm Firewall on as well in full stealth as well boy am I happy, I am on
18-10-2007 9:02 AM
But that is like a child closing their eyes, and saying now you can't see me!
What you have done, is great protection from casual attacks. But some encryption even if it is only WEP would also be helpful.
If your hardware supports WPA that that would be best.
Chilly
18-10-2007 12:09 PM
Your MAC locking will stop the casual person who just wants to hijack the nearest wifi signal.
Wifi is a security pain.
If you feel confident:- try the following
1) Change the default password on your router.
2) Install WEP or WPA - either will stop the casual person.
WEP can be easily broken in a couple of minutes, WPA is much harder to crack.
18-10-2007 2:04 PM
But it goes to show just how easy it is for a stranger to use your WiFi network if it is not protected. I did not take advantage by downloading masses of data, because I would have been stealing bandwidth which may have been capped.
So any Canadians reading this, if any of my connections were through your WiFi, many thanks ! And sorry you did not do better in the Rugby.
19-10-2007 12:27 AM
Quote from: chillypenguin [snip] But that is like a child closing their eyes, and saying now you can't see me!
I definitely am not closing my eyes. I take internet security very seriously indeed.
Quote from: PJ [snip] I agree- install WPA if your equipment supports it.
To be honest with me bean dyslexic I don't know watt the equipment supports!
Quote from: axisofevil [big snip] Change the default password on your router.
That was the first thing I did!
Quote [snip] Install WEP or WPA - either will stop the casual person.
How do I do that? and where do I get WPA from?
19-10-2007 1:09 AM
However, at present all your data is being sent on your wifi in clear text - it could be read by anyone with a laptop within wifi range.
Whilst it's easy to get paranoid about this, it is fairly easy to arrange for your wireless data to be encrypted. This is where the WEP or WPA protocols come in. There will be an appropriate interface in your PC drivers/network interface and in your router settings.
Basically, you need to set up a passphrase which is used to encrypt the wifi data.
19-10-2007 1:23 AM
Quote Security
This page allows you setup the wireless security. Turn on WEP or WPA by using Encryption Keys could prevent any unauthorized access to your wireless network.
Encryption :
Disable
WEP
WPA pre-shared key
WPA RADIUS
WPA Unicast Cipher Suite :
WPA(TKIP)
WPA2(AES)
WPA2 Mixed
Pre-shared Key Format :
Passphrase
Hex (64 characters)
Pre-shared Key:
Please see the Screen Shot 1 and Screen Shot 2 as well.
[Edit]
Will I need any software on the PC ?
19-10-2007 11:49 PM
http://www.robdickson.co.uk/PC_Advice/Networking/securing_wireless_networks.php
WPA is the only real way to secure your network, but all the other things can make things more difficult.
