Wireless network drops out when second computer connects
- Wireless network drops out when second computer co...
22-07-2012 10:47 AM
Dear fellow members,
I wonder if anyone would be able to offer me some advice on this. I have two computers at home which link wirelessly to the Thomson router provided by Plusnet. Recently, when one is connected and the other connects, the wireless drops and both are disconnected. One is an XP machine, and the other a Windows 7 machine.
This problem has only occurred in the last week or so, and I cannot think that either computer has been changed in a way that might affect the connection. I did wonder if it was a DHCP issue, so I put both machines on a fixed IP, but that has made no difference.
Can anybody offer any suggestions as to the cause / cure?
Message 1 of 5
(1,140 Views)
4 REPLIES 4
Re: Wireless network drops out when second computer connects
22-07-2012 11:12 AM
Welcome to the forum. Is that the 585v8 you are referring to? Do you have any ethernet cables that you could connect one or both computers with to see if it's a wireless issue or modem/router problem?
Message 2 of 5
(544 Views)
22-07-2012 11:43 AM
How you you restore wireless connectivity? If it is by rebooting your router you need to be careful because if you do it too often the exchange is likely to interpret the frequent disconnects as line instability and lower your speed to try and make it more stable.
Message 3 of 5
(544 Views)
22-07-2012 2:20 PM
If it is the 585v8, the following may be useful -
TG585v8 Rebooting When Laptop Connects
Thomson 585v8 Wireless compatibility Issues
Message 4 of 5
(544 Views)
22-07-2012 7:45 PM
Thank both for your swift replies - very helpful.
The source of the problem was the power management setting on the network adapter. I've disabled it now, and the problem seems to have abated.
Thanks again
Thanks again
Message 5 of 5
(544 Views)
