Wireless issues TG582n
- Wireless issues TG582n
- « Previous
- 1
- 2
- Next »
Re: Firmware for Technicolour TG582n router
19-08-2015 9:28 PM
My router is always on.
I hope that the new Firmware will improve the wireless signal, as its very patchy
Message 16 of 22
(280 Views)
Wireless signal issues Techicolour TG582n router
20-08-2015 9:27 PM
Having problems with the wireless signal. Having to manually select a different channel regularly, and connection drops. Any ideas?
Message 17 of 22
(280 Views)
Re: Wireless signal issues Techicolour TG582n router
21-08-2015 2:34 AM
It sounds like an interference problem. Have your tried running inSSIDer free to check your wireless environment and see what other routers are around you. If you have the 10.2.5.2 Firmware you can try running http://192.168.1.254/WIFI_Analyzer.lp see what that shows. There's also free apps for mobile from the various stores - WiFi Analyzer is one such from Googleplay for Android.
Message 18 of 22
(280 Views)
21-08-2015 8:21 AM
Is this after Chris has pushed out the firmware upgrade or has that not happened yet. Could be off not seen a post for a day or 2
@ AO Maybe these threads should be combined?
Message 19 of 22
(280 Views)
21-08-2015 10:00 AM
Will have to check.
Message 20 of 22
(280 Views)
21-08-2015 10:47 AM
Yep, I agree. Poster has 3 threads running and are relevant to this issue. Chris hasn't been on so upgrade may not have happened. Perhaps welshguy2010 could check. Hopefully a mod can merge the 3 threads.
Message 21 of 22
(280 Views)
Re: Technicolor TG582n routers
21-08-2015 4:44 PM
Mod Note
3 topics merged to keep things tidy and manageable.
Message 22 of 22
(280 Views)
- « Previous
- 1
- 2
- Next »
