Wireless connectivity on the Thomson V8
- Wireless connectivity on the Thomson V8
Re: Wireless connectivity on the Thomson V8
06-12-2010 2:46 PM
I joined PlusNet and couple of weeks ago and purchased the Thompson wireless router as part of the package to replace a similar O2 unit on that's now gone back.
Since plugging it in and setting it up I've had nothing but trouble with the wireless connection - dropping signal, rejected passwords for no reason before connecting, limited connectivity on my laptop and random disconnection on numerous devices.
I've checked I'm on a clear channel that isn't being used by the neighbours (I'm on 1, they're on 6 and 11, so that's fine) and get good signal strength around the house, but still have problems.
One thing I have noticed is that if I switch to WEP, rather than WPA, I don't seem to have anywhere near as many problems with key authentication. However, I'm not prepared to continue with WEP as it's just not secure. The other cure is to reboot the router, but that's not practical every couple of hours!
These wireless problems are driving me mad as I've got eight devices that I can't connect any other way!
06-12-2010 5:10 PM
Does the pattern of key authentication problems change if you select (and Apply) either WPA or WPA2 (only, rather than both) in the WPA-PSK Version box at the bottom of the configuration page?
06-12-2010 5:17 PM
I haven't tried changing to WEP yet, that's my next port of call when I get back.
jim:quote
06-12-2010 5:34 PM
jim:quote
06-12-2010 7:29 PM
06-12-2010 8:14 PM
07-12-2010 9:12 AM
It really appears that there is a problem with the wireless functionality of this model modem / router or at the very least a compatability problem with certain wireless cards.
I would appreciate a fix when available, as I have a new wireless modem router that is not really useful to me for anything other than a paper weight at the present time.
Tks,
AndrewD
07-12-2010 4:21 PM
07-12-2010 9:48 PM
07-12-2010 9:52 PM
Quote from: TheMacca I actually tried this, changed to WPA2 then to WPA but still get the same behaviour.
I just changed to WEP128. For the first time ever, the password is accepted straight away AND my airport express is now able to join the network (again for the first time since putting the Thompson live).
Sound like an issue with WPA or WPA2?
//ian
09-12-2010 10:49 AM
As it stands I have a wireless router that I paid for that doesn't do what it advertises. I'd like one that works or I think I'd like my money back for the router!
09-12-2010 11:01 AM
Thanks for all the responses. I can see that you're all having various issues with the V8. In order for me to now collate these with other examples I already have I would appreciate it if you could now post your issues like this...
Example....
Device: Laptop
Make: Dell
OS: Windows 7
Issue: Drops connection/refuses password/never connected
In the event your device is a printer etc. leave the OS as n/a
Thank you all for your help.
Jojo
09-12-2010 11:56 AM
Make: Apple
OS: OS X
Issue: Drops connection then refuses password multiple times before eventually reconnecting (WPA/WPA2)
Device: Laptop
Make: Lenovo
OS: Vista
Device: iPad x 2
Make: Apple
OS: iOS 4.2
Device: iPhone
Make: Apple
OS: iOS 4.2.1
Device: Mobile Phone
Make: LG Optimus 7
OS: Windows Phone 7
Make: HTC Desire
OS: Android 2.2
Device: Printer
Make: Xerox 6125N
OS: N/A
Issue: Drops connection then requires router reset to reconnect - after that it stays connected for only 10-15 minutes (WPA/WPA2)
09-12-2010 12:14 PM
All included in my post.
Quote from: Joanne Device: Laptop
Make: Dell
OS: Windows 7
Paul
09-12-2010 12:29 PM
Make: Acer 7720g
OS: Vista
Issue: Drops DSL connection
Additional: wireless shows 99% strength
Additional2 : Windows 7 machine stays connected
