Wireless connectivity on the Thomson V8
- Wireless connectivity on the Thomson V8
Re: Wireless connectivity on the Thomson V8
16-12-2010 1:41 PM
Welcome back. Although i don't remember you from the first time around as I was only 16!
Thanks for the information, I will add it to my list.
Jojo
16-12-2010 1:52 PM
OK it could partly be the cold doing things to BT wires, never happened last winter though!
16-12-2010 2:06 PM
We're not certain that it is definitely a firmware issue as such, and I have only just over 20 issues at the moment. The fact that we have well in excess of 20,000 of these units out there means that only a minute percentage are affected. However, we will soon be publishing the firmware that has been fixing the mac device wireless issue so you guys will be more than welcome to see if it fixes your issue, I suppose.
Jojo
16-12-2010 3:29 PM
Have another modem/router on order .... which as things are going right now might be here by spring .... will be interesting to see if a netgear product does any better .... might not!
16-12-2010 4:14 PM
Device: Laptop (Macbook Pro)
Make: Apple
OS: OS X 10.6.5
Problem: I've been having the issues with the invalid password for the wireless after the laptop wakes from sleep, with restarting the laptop fixing the issue. I've also got a discrepancy in the upload speed:
Today 15:58 5800 kbps (725kB/s) 377 kbps (47.1kB/s) Wired
Today 15:52 5759 kbps (720kB/s) 36 kbps (4.5kB/s) Wireless
Will the fix work for both these issues?
Nobby
16-12-2010 4:27 PM
I can raise the wireless connectivity issue to be fixed but I'd be really interested to know if it sorts out the upload issue, so you must let me know as there are a couple of others having the same problem.
Jojo
17-12-2010 10:47 AM
Nobby
17-12-2010 11:34 AM
Going by something I read earlier, I changed the wireless SSID from PlusnetWireless******* to PW** and that seemed to do the trick, at least in the short term. Can somebody please recap if there is something else I should have done?
17-12-2010 2:09 PM
Device: Laptop
Make: Toshiba
OS: Vista
Issue: Frequent "limited connectivity" - may have been fixed by shortening the SSID
Device: iPad
Make: Apple
OS: As supplied
Issue: Frequent no internet connection - not fixed by shortening the SSID
17-12-2010 3:08 PM
I will get this upgraded for you and you can tell me if it sorts both laptops out.
Jojo
17-12-2010 3:09 PM
This has now been completed, can you tell me how it went. Did it cure the wireless and the upload?
Jojo
17-12-2010 5:22 PM
It appears to have fixed both the wireless and the upload speed issues :). Thanks!
Nobby
17-12-2010 5:32 PM
Doubt I'll have to ask for any help for at least a year now
17-12-2010 7:22 PM
i was having limited connectivity issues
18-12-2010 11:53 AM
Rei
