Wireless connection problem with TP-Link's TD-W8960N (ADSL2+) Router
soccmn
Recently bought this router, and whilst I can connect to web via ethenet no problem, I can't connect wirelessly. Not very techy, and so not sure what I am doing wrong. I have Wireless Enabled checked, and can see the wireless network but it just won't connect. Any ideas (in as lay terms as possible please!) thanks.
chandu
Re: Wireless connection problem with TP-Link's TD-W8960N (ADSL2+) Router
Have you changed your SSID and related password?  If not, try changing it and then try to log-in wirelessly to that SSID.
This just a suggestion.
soccmn
Yes - have switched it a couple of times, but no joy.
chandu
Okay,
Can you try SSID called something different - the security password can remain same as old one.  Then try and sync into the wireless, using your laptop, with your security password.
It happened to me last I had updated the router firmware and I had to change my SSID name.
