Wireless connection problem with TP-Link's TD-W8960N (ADSL2+) Router
- Re: Wireless connection problem with TP-Link's TD-...
19-03-2011 6:10 PM
Recently bought this router, and whilst I can connect to web via ethenet no problem, I can't connect wirelessly. Not very techy, and so not sure what I am doing wrong. I have Wireless Enabled checked, and can see the wireless network but it just won't connect. Any ideas (in as lay terms as possible please!) thanks.
Message 1 of 4
(3,937 Views)
3 REPLIES 3
Re: Wireless connection problem with TP-Link's TD-W8960N (ADSL2+) Router
19-03-2011 7:32 PM
Have you changed your SSID and related password? If not, try changing it and then try to log-in wirelessly to that SSID.
This just a suggestion.
Message 2 of 4
(1,060 Views)
20-03-2011 10:19 AM
Yes - have switched it a couple of times, but no joy.
Message 3 of 4
(1,060 Views)
20-03-2011 4:46 PM
Okay,
Can you try SSID called something different - the security password can remain same as old one. Then try and sync into the wireless, using your laptop, with your security password.
It happened to me last I had updated the router firmware and I had to change my SSID name.
Message 4 of 4
(1,060 Views)
