Wireless connection issue
- Wireless connection issue
25-12-2023 3:30 AM
Hi!
Can anyone advise why the wireless connection from my BT keeps dropping off when my daughter is online gaming? Additionally, it may be unrelated, but my printer has decided to stop printing wirelessly from my laptop.
Many thanks in advance for replies.
Attempting to diagnose any problems I came up with this:
Test the connection to your ADSL service provider
Test ADSL Synchronization: PASS
Test ATM OAM F5 segment ping: FAIL
Test ATM OAM F5 end-to-end ping: FAIL
It's probably unrelated but I'm no great techno
live sex - The advanced technology on these sites allows for high-definition video and audio, providing an immersive experience.
POV Cams with Girls Live - Many users find these sites to be a safe space to express their deepest desires without fear of ridicule.
Re: Wireless connection issue
25-12-2023 9:05 AM
Are you a BT Broadband customer, or Plusnet? If the former, the BT Customer forums are here:
25-12-2023 11:02 AM
@Noumenalism wrote:
... ... the wireless connection from my BT keeps dropping off
What is a "BT" ? - BlueTooth ?
@Noumenalism wrote:
... ... why the wireless connection from my BT keeps dropping off when my daughter is online gaming?
What are the symptoms ?
Does the wireless indicator show a disconnection ?, or does the wireless remain connected but the traffic stalls ?
@Noumenalism wrote:
... ... when my daughter is online gaming?
Does she have a wired Ethernet connection ?
What is she playing on ? - a console, a PC - and if a PC is it a program or using a web browser ?
Are you definitely on ADSL, and not FTTC or full fibre ?
Try this -
Using a WIRED connection, when NOBODY is using your internet, run this test - https://www.waveform.com/tools/bufferbloat
Then post back here a screenshot, showing the "Bufferbloat Grade", "Latency", and "Speed" results
@Noumenalism wrote:
... ... my printer has decided to stop printing wirelessly from my laptop.
What printer is it ?
Check the manufacturers website, and install the latest printer firmware, and updated printer drivers for your PC etc.
Then try resetting the printer back to factory settings, and then re-installing as if it was new.
