Wireless connection intermittent
- Wireless connection intermittent
- « Previous
- 1
- 2
- Next »
Re: Wireless connection intermittent
27-10-2007 1:43 PM
Are you using WPA2 security on the router? That required a patch to be installed on XP SP2, KB917021.
I just wondered if that was relevant to your situation (another straw). If you had it originally restoring the registry could have removed it.
David
Message 16 of 22
(507 Views)
27-10-2007 5:10 PM
Hi8. I'm using WPA-PSK (no sever) TKIP encryption. Whatever, I downloaded the patch you gave me and the connection works at this moment. I'll keep you informed as to how it goes. Fingers crossed and everything else.
Many thanks for your persistence.
Message 17 of 22
(507 Views)
27-10-2007 5:27 PM
Well, the connection drops out, I am unable to manually connect and then the connection makes automatically. Most confusing
Message 18 of 22
(507 Views)
27-10-2007 11:05 PM
Sorry, I've run out of straws too.
David
Message 19 of 22
(507 Views)
29-10-2007 12:03 AM
I had similar troubles with my Belkin router. I ditched it in favour of a BT Voyager 2110 since when I have only dropped connection on two occasions.
Message 20 of 22
(507 Views)
01-11-2007 12:06 PM
Thanks for your input. I have had horrendous broadband connection problems the last few days which are now improving; hence my lack of response here.
However, I have downloaded the latest drivers for my Belkin PCI wireless card and the connection, ATM, is fine. Again, fingers crossed but things are looking hopeful.
Cheers
Cheers
Message 21 of 22
(507 Views)
02-11-2007 9:35 AM
Well, installing the latest drivers (2005!) has done the trick as the wireless connection has been solid. My poor broadband connection was caused by water getting into a BT connection some distance from my house so that will be fixed soon.
Thanks for the input guys.
Message 22 of 22
(507 Views)
- « Previous
- 1
- 2
- Next »
