Wireless Router + Ethernet
- Wireless Router + Ethernet
22-01-2012 11:12 AM
At present I am using a Thomson router connected to my desktop by Ethernet cable.
My question is: Can I use the WiFi capability of the the router to run a laptop while continuing to use the Ethernet cable to connect to the desktop?
[Moderator's note by Dick(Strat) All caps title edited as per forum rules.
Message 1 of 3
(734 Views)
2 REPLIES 2
Re: WIRELESS ROUTER + ETHERNET
22-01-2012 11:29 AM
Yes you can without any problems at all.
Message 2 of 3
(330 Views)
22-01-2012 11:39 AM
BRABUS, many thanks for your swift response!
Message 3 of 3
(330 Views)
