Wireless N Router with Broadcom
julesandsand
I've been advised to try a modem/router with a Broadcom ADSL chipset due to the length of my line.
I've been browsing some of the manufacturer's websites but the chipset never seems to be mentioned. I got a D-link 2740R but have sent it back to the supplier because of frequent dropped connections.
Any ideas?
Steve
Seasoned Pro
Re: Wireless N Router with Broadcom
Go here http://www.dd-wrt.com/site/support/router-database And type In broadcom.
If life gives you lemons, make lemonade.
Look on ebay for a Voyager 2110. It's discontinued but a very good router and there are always a few around for sale. It has a Broadcom BCM6348 v0.7 chip.
julesandsand
The Voyager isn't wireless N.
Fixes: 126
The billion bipac 7800n has a broadcom chipset and is N. solid on my line and a couple of other pn customers.
Will Moderate For Thanks
julesandsand
@adiewoo - thanks for that. They seem proud that it has a Broadcom chipset!
I'll give that one a go.
julesandsand
Just a thought - can the aerials be upgraded to higher gain ones?
