Wireless Issue
- Wireless Issue
Wireless Issue
31-03-2014 12:25 PM
Please bear with me, I'm new to this forum.
I joined PlusNet from BT in November and service was great for a while. In past 2 months I have had progressively more problems with the wireless connection (I think). In the last week, the wireless light has sometimes been unlit (router problem?), but when it is lit, both my laptop and wifes tablet are having disconnection issues (websites not loading etc.
Any suggestions would be appreciated. Logged into router to get some info for this morning (where I have connected via Ethernet and wireless) - see below
Mar 31 12:00:13 IDS scan parser : tcp port scan: 157.56.194.24 scanned at least 10 ports at 87.112.124.233. (1 of 1) : 157.56.194.24 87.112.124.233 40 248 TCP 443->55975 [..AR..] seq 3047858194 ack 3744814594 win 0
Info Mar 31 11:59:17 LOGIN User admin logged in on [HTTP] (from 192.168.1.65)
Info Mar 31 11:50:05 LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
Error Mar 31 11:34:42 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 67.209.65.254 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Info Mar 31 11:20:37 SNTP Synchronised to server: 212.159.13.50
Error Mar 31 11:14:12 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 134.90.227.207 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Protocol Unreacheable
Info Mar 31 10:57:16 LOGIN wireless station [20:16:d8:a2:70:a7] can't get authorized.
Error Mar 31 10:49:23 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 186.208.208.34 Dst ip: 87.112.124.233 Type: Time Exceeded Code: Time to Live exceeded in Transit
Error Mar 31 10:26:24 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 122.249.72.195 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Info Mar 31 10:20:37 SNTP Synchronised again to server: 212.159.13.49
Error Mar 31 09:49:33 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 209.239.171.159 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Info Mar 31 09:48:38 LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
Info Mar 31 09:41:16 CONFIGURATION mbus igd sync successfull
Info Mar 31 09:41:13 CONFIGURATION mbus atomic sync successful
Info Mar 31 09:38:08 CONFIGURATION mbus igd sync successfull
Info Mar 31 09:38:05 CONFIGURATION mbus atomic sync successful
Info Mar 31 09:34:27 LOGIN User admin logged in on [HTTP] (from 192.168.1.65)
Error Mar 31 09:30:06 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 173.224.208.180 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Error Mar 31 09:28:29 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 180.65.171.218 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Info Mar 31 09:20:37 SNTP Synchronised to server: 212.159.13.49
Error Mar 31 08:25:54 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 118.221.67.39 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Info Mar 31 08:20:37 SNTP Synchronised to server: 212.159.13.50
Error Mar 31 08:18:03 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 58.239.161.55 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Error Mar 31 08:08:03 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 116.120.25.174 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Error Mar 31 07:44:02 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 203.227.210.137 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Info Mar 31 07:20:37 SNTP Synchronised to server: 212.159.6.10
Error Mar 31 06:53:59 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 180.140.85.102 Dst ip: 87.112.124.233 Type: Destination Unreachable Code: Port Unreacheable
Message 1 of 2
(671 Views)
1 REPLY 1
Re: Wireless Issue
01-04-2014 9:50 AM
Hi Exbtpat,
The logs don't indicate any wireless issues. When the wireless light on your router goes off do you know if the wireless network is available if your available networks on your tablet?
It may also be worth trying to change your wireless channel - http://www.plus.net/support/broadband/hardware/technicolor-582n-wireless.shtml
Message 2 of 2
(319 Views)
