Wireless Adaptor
- Re: Wireless Adaptor
Wireless Adaptor
01-11-2014 5:54 PM
My broadband dropped and I went into Windows Net Diagnostics and I was told there was a problem with the wireless adaptor and in the next instance it had fixed the problem in no time,I am not sure what this means have I a faulty wireless adaptor.
Message 1 of 5
(779 Views)
4 REPLIES 4
03-11-2014 12:30 PM
Hi valart
I have encountered the issue a couple of times myself with my Desktop, It usually just requires me to unplug the adaptor and plug it back in again, the classic fix I know
I'm unsure of the reasoning behind it, but hopefully the connection is now working ok and it was just a glitch
Regards
Matt
Regards
Matt
Message 2 of 5
(408 Views)
03-11-2014 5:59 PM
Thanks for your reply I will try what you said if it happens again my only problem with that is my laptop that I use is upstairs and is plugged into my speakers for when I listen to music,so it means running downstairs where my router is.
Message 3 of 5
(408 Views)
04-11-2014 9:53 AM
I don't understand. The wireless adapter will be in your laptop, so you shouldn't need to go near the router. Just unplug and reconnect the adapter in the laptop itself.
Message 4 of 5
(408 Views)
04-11-2014 10:11 AM
If the wireless adapter is built in to the laptop, a lot of laptops have a little switch to turn it off and on again.
If it is built in and you don't have a switch, you can disable/enable it in Device Manager (tedious), or I can give you a short .cmd file which is easier to access as you can put a shortcut into start menu.
Message 5 of 5
(408 Views)
