Wired vs Wireless speed tests
- Wired vs Wireless speed tests
01-04-2013 2:13 PM
..... and this is why you should use a wired connection for your speed tests !
It would have been better if I was hitting my usual 70mb speed but t'internet is a little slower today. Last week I had a modem sync of 65mb before I had to reboot the modem and router - it resynced at 75mb. Not bad considering the speed esitmate for my line was 50mb
Message 1 of 3
(1,023 Views)
2 REPLIES 2
Re: Wired vs Wireless speed tests
02-04-2013 12:48 PM
Message 2 of 3
(444 Views)
02-04-2013 12:57 PM
Mine is just like that; wireless to the same PC is about 30meg, using a powerline connection it's up to 70meg or so.
Message 3 of 3
(444 Views)
