Windows Update help
- Windows Update help
Windows Update help
27-08-2008 7:36 PM
This auto-update from Windows downloads and installs each time I log on (Daily). Been doing this since Oct last year. I've Google'd it and searched through the Windows info site but can't find anyone else with same problem. Widows says it is updated monthly!
Decided I should do something now as it's bugging me.
Windows Malicious Software Removal Tool - August 2008 (KB890830)
Thanks in advance,
Moggy
Re: Windows Update help
27-08-2008 8:01 PM
27-08-2008 8:06 PM
puddy
27-08-2008 8:11 PM
Are other/later updates going in OK?
27-08-2008 8:12 PM
Thanks for that, but it does not fail to install, it just keeps installing!!!!!!! The Status shows 'Successful'. I would think I have about 100 'Successfuls'. All other updates are OK.
I've got Vista SP1, and maybe it's something to do with Nortons, just don't know. I was hoping someone else had the same thing and found a way around it.
Anyway, thanks again.
Moggy,
27-08-2008 8:15 PM
27-08-2008 9:40 PM
Oh for Windows 3.1............................ just joking
27-08-2008 10:08 PM
It's actually Tuesday and the second Tuesday of the month. Also known as "Patch Tuesday" but whats a few hours between friends
Unfortunately I cant help with your problem Moggy. Sounds well random.
27-08-2008 11:11 PM
28-08-2008 4:28 AM
Apparently, downloading and installing the update manually should fix the problem.
28-08-2008 7:17 PM
tried it and just for a minute all looked good, then it all began to loop again again again again again again
