Winchester connection slowing down recently
- Winchester connection slowing down recently
18-06-2011 6:51 AM
I just ran a speedtest with the BT tester (6AM this Saturday morning):
Download speedachieved during the test was - 1539 Kbps
Additional Information: Your DSL Connection Rate :3104 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 2500 Kbps
These are the results from my Thomson Router:
Link Information
Uptime: 6 days, 2:14:07
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,104
Output Power (Up/Down) [dBm]: 12.0 / 17.0
Line Attenuation (Up/Down) [dB]: 30.0 / 49.0
SN Margin (Up/Down) [dB]: 24.0 / 7.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 6 / 0
FEC Errors (Up/Down): 0 / 6,686,916
CRC Errors (Up/Down): 0 / 2,244
HEC Errors (Up/Down): 0 / 2,008
Is there anything that PlusNet or I can do to make this faster? I was thinking of purchasing a new router at some point in time to perhaps speed things up. Would that help?
Re: Winchester connection slowing down recently
18-06-2011 6:55 AM
It says I should be seeing real world speeds of up to 4 Mbit .... I wish!
18-06-2011 1:24 PM
(Assuming you can get at it - I can't seem to access the main PlusNet site just now...)
18-06-2011 1:59 PM
18-06-2011 3:57 PM
Phone exchange:
WINCHESTER
Estimated line speed:
1.5Mb (This may vary between 1Mb and 3.5Mb) - Checked on 2011-05-07 10:55:28
Current line speed:
1.75 Mb
How can I get it to go to 3.5Mbit?
Also, I removed some really bad wiring in the faceplate. Numbers look ever so slightly better as far as I can tell; my SN Margin looks terrible though. Is this normal?
Link Information
Uptime: 0 days, 2:07:27
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,736
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 30.0 / 48.0
SN Margin (Up/Down) [dB]: 24.0 / 6.5
Error Seconds (Local/Remote): 7 / 0
FEC Errors (Up/Down): 0 / 72,878
CRC Errors (Up/Down): 0 / 401
HEC Errors (Up/Down): 0 / 365
18-06-2011 4:04 PM
As to why your sync speed is low - it could be a number of things but the first thing to note is that your last resync was at about 4.00am which is the worst possible time.
You should resync during daylight which will give you a higher sync speed.
It would be worth trying the test socket at the same time
20-06-2011 11:32 AM
The profile on your account is now 4000. Are you seeing an improvement at your end?
Jojo
20-06-2011 1:40 PM
I love you Jojo! I haven't seen the line this fast ... ever!
21-06-2011 9:56 AM
22-06-2011 8:50 PM
22-06-2011 9:17 PM
ok I've got my coat and gone
23-06-2011 11:01 AM
Quote from: Mansn Just to let you know - the connection is still rock solid on 3.8 Mbit
Awesome!
