Will turning off interleaving speed up my broadband? I'm not a gamer
- Will turning off interleaving speed up my broadban...
03-10-2016 5:22 PM
Will turning off interleaving speed up my broadband? I'm not a gamer and don't know what 'ping' is, I just have very slow broadband and would like some easy tips on how to make it faster. It's frustrating as I can't stream iPlayer or anything on my computer and when there are two of us at home we can barely even get any browsing done. Very frustrating and nowhere near the speed we're paying for. The last test came up as 0.7MBS. Can someone do some tests and help sort us out please?
Re: Will turning off interleaving speed up my broadband? I'm not a gamer
03-10-2016 11:33 PM
Will turning off interleaving speed up my broadband? - NO !
If your connection is not achieving it's full potential sync speed, then having interleaving switched ON will almost certainly provide a greater real-world throughput than running FASTPATH (i.e. interleaving off).
Theoretically, slightly greater data bits per second can be transferred with interleaving off, however that minuscule improvement will be wiped out many times over if there are errors present on the connection - due to the need to resend any corrupted data packets (which are very large in comparison to the few bits saved without interleaving).
Interleaving is used to assist the error correction capability of your modem. The more effective the error correction is, then the need for retransmissions is reduced, which in turn maximises throughput.
Do you know what speed your line should be achieving ?
If not, try entering your phone number into the 'BT BROADBAND AVAILABILITY CHECKER'
04-10-2016 7:25 AM
That's not totally correct. Some lines have interleaving put on when it is not needed.
What you need to do is look at the detailed router stats and see how many FEC errors you are getting. If it is very low turning off interleaving may give you a small speed increase. If you are getting a lot of FEC errors you are far better leaving interleaving on.
04-10-2016 11:09 AM
Estimates:
ADSL Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Range(Mbps) |
Availability Date |
Left in Jumper |
WBC ADSL 2+ | Up to 2.5 | -- | 1.5 to 4 | Available | -- | -- |
Your line is testing as:
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 44.3 | 63.5 |
SNR Margin: | 10.0 | 6.5 |
Errored Seconds: | 0 | 1 |
HEC Errors: | 0 | |
Cell Count: | 553797 | 2982363 |
Speed: | 480 | 1440 |
Maximum Stable Rate (KBPS): | 576 | Fault Threshold Rate (KBPS): | 460 |
Mean Time Between Retrains (Seconds): | 86400 | Mean Time Between Errors Upstream (Seconds): | 4547 |
Indicative Line Quality: | G | Mean Time Between Errors Downstream (Seconds): | 382 |
So from that it appears your line is quite long (63.5db is the maximum that some lines show) and there aren't many errors. However it's connecting below the estimates but above the fault threshold rate (which is what allows us to report a speed fault on an ADSL line).
Can you confirm how you're connected internally? Are you in the master socket without any extension leads and are you using wireless or wired connections?
04-10-2016 4:43 PM
I'll assume it's operating on ADSL1 for no good reason rather than ADSL2?
04-10-2016 7:22 PM
@Anonymous @jelv
I wouldn't say either of those explanations about interleaving are quite right, but in any case, such a long line is almost certainly better with interleaving on. My own line isn't quite as long as this one, but I get more bandwidth with interleaving on than off. So how does that work, since the error correction data uses up some of the bandwidth? It's because the error correction ability is factored in (coding gain) when the modem determines what speed it can connect at.
04-10-2016 8:06 PM
It's because interleaving encodes data in a way that incorporates more data redundancy, so that you get a signal that includes a greater degree of automatic error correction. This reduces requests for resending of packets (a slow option).
You don't get a free lunch, so speed reduces but your connection is more stable.
04-10-2016 8:19 PM
Here's a graph to illustrate what I actually get.
04-10-2016 8:23 PM - edited 04-10-2016 8:33 PM
Have a skim read of http://www.kitz.co.uk/adsl/interleaving.htm
04-10-2016 8:40 PM
Any particular reason? They already said they weren't concerned about latency, and neither am I.
04-10-2016 9:51 PM
Nor me.
