Will speed improve...?
- Will speed improve...?
19-05-2012 2:34 PM
I hope it will anyway
Re: Will speed improve...?
19-05-2012 2:52 PM
19-05-2012 2:59 PM
Uptime: 1 day, 16:57:41
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1.088
Data Transferred (Sent/Received) [MB/GB]: 394,13 / 1,99
Output Power (Up/Down) [dBm]: 12,5 / 16,3
Line Attenuation (Up/Down) [dB]: 31,5 / 60,0
SN Margin (Up/Down) [dB]: 13,0 / 22,4
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 16 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 4.265 / -
FEC Errors (Up/Down): 274 / 558
CRC Errors (Up/Down): 9 / 11
HEC Errors (Up/Down): - / 11 / 43
Is this the right info?
19-05-2012 3:14 PM
However with the information you have given something is adrift.
I suspect that your line has been banded.
Do you have a test socket - see the video link in the post I linked to earlier - if so can you try the router in there and report the stats again
To answer the original question you should get over twice the speed you are
19-05-2012 3:36 PM
Download Speed: 0.94 mbps
Upload Speed: 0.33 mbps
Ping: 76.50
19-05-2012 3:37 PM
Estimated line speed:
1.5Mb (Accurate to within +/- 1Mbit) - Checked on 2012-05-04 17:42:02
Current line speed:
7.15 Mb
19-05-2012 3:39 PM
19-05-2012 4:57 PM
Use this link and put in your telephone number only http://www.speedtester.bt.com/
19-05-2012 5:19 PM
1. Best Effort Test: -provides background information.
Download Speed
0.88 Mbps
0 Mbps 1 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.88 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-1 Mbps.
IP Profile for your line is - 0.96 Mbps
Upload Speed
0.36 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.36Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
19-05-2012 5:31 PM
The usual reason for banding is a large number of disconnections in a very short time
19-05-2012 11:28 PM
20-05-2012 11:31 AM
I'm using a wireless connection, yes.
20-05-2012 11:36 AM
20-05-2012 12:11 PM
20-05-2012 5:52 PM
