Will once a day power on/off trigger DLM?
- Will once a day power on/off trigger DLM?
Re: Will once a day power on/off trigger DLM?
23-10-2014 10:13 AM
To answer a couple of Adam C's questions:
1. The router is a Netgear N300 ADSL 2+, bought as a new replacement for the Technicolor router supplied by PlusNet. However, dropped connections happen equally with either router.
2. I'm NOT turning off the router once a day - so far it has been always on. My original question was whether it is OK to put the router on a time switch and briefly disconnect the power every day as a way to fix dropped connections. However, the opinion of the Forum is that this could cause DLM issues, which would not be ideal as our download speed is only 1-2MBPS.
So...our connection appears to be down again and will stay that way until I'm next at my Yorkshire Dales address and can physically reboot. It would be nice to get to the bottom of the problem.
Will PN pick this up from here or should I raise a new ticket?
The extra advice I've had from forum members is very much appreciated.
23-10-2014 11:18 AM
I would suspect that there is a phone line problem requiring investigation, which will mean being there to do it.
Would this be a holiday home not normally occupied? If yes, sorting this could be a pain in the neck.
Kevin
23-10-2014 11:43 AM
- you have a computer in the building with camera
- it is the DSL connection that is failing and not something else related to the router, so the computer can still access the router
Then
- you could arrange the computer to wake up every now and then,
- check the router,
- reset the router if necessary.
Even something like a Raspberry Pie should be enough; possibly cheaper than any custom devices.
23-10-2014 12:01 PM
sjptd - thanks also for this suggestion. I don't leave a computer at this address, just the camera and router. Configuring a Raspberry Pi to reboot the router would not fall within my IT skills, unfortunately.
23-10-2014 5:49 PM
23-10-2014 8:58 PM
23-10-2014 11:15 PM
24-10-2014 12:39 AM
24-10-2014 12:59 AM
However
The consideration of having DLM turned off, even if it is only temporary, whilst you seek a more permanent solution
24-10-2014 7:17 AM
If you have an intermittent iffy joint or a battery or earth fault, it can/will cause a lot of noise on the line (from the ADSL modem point of view). This will prevent it reconnecting whilst the noise is present. It is highly likely that the noise will be audible as well.
Quote from: Dalesman Townman - thanks. Yes, it is a second home. What phone line checks would be in order, other than a noisy line test (17070) which I admit I forgot to do last time I was up there? We have 2 miles of overhead phone line from the green cabinet, so I guess we can't expect perfection.
Oh yes you can expect perfection, that is what you pay your line rental for. You need to do the quiet line test (option 2) as mentioned by Townman. Any sign of any crackles, pops etc means a fault. The trouble with intermittent faults is catching it at a time it's happening. Who do you pay line rental to?
One other trick you can try is ring the landline of the property when it seems not to be connected. The ringing current will sometimes clean an iffy joint sufficiently. As has already been mentioned, reconnects are better in daylight hours especially on very long lines because background noise levels are usually lower (leaving faults aside) an you will normally get a faster sync speed.
On the subject of modem/routers - the Technicolor shouldn't give an issue if it has the latest firmware. Is it the TG582n and has it got a USB socket? Log into it and check the firmware version (it doesn't have to be connected to the line to do this) just the computer which you may need to reboot to pickup the correct LAN setting.
Also your Netgear, there have been some issues with some recent Netgear's as well, check that it has the latest firmware also.
24-10-2014 10:10 AM
Will check and update router firmware when I'm next in the Dales.
One question - I just tried ringing the line as you suggested. Does the router keep trying to reconnect or just give up? Once it's down, it stays down until I next visit and reboot the router.
24-10-2014 10:44 AM
24-10-2014 10:55 AM
Quote PN have suggested the disconnections could be due to BT maintenance at the exchange and sometimes forgetting to send a reconnect signal. But this would imply on-going maintenance week by week and a lot of forgetfulness.
When set to Always Connected my 3com router reconnects automatically after a disconnection without needing a signal from BT to tell it. I have just unplugged my telephone line from the router and this is what the log shows (with IP addresses partially redacted).
[tt]2014.10.24 10:14:52 If(ATM1) PPP connection ok !
2014.10.24 10:14:51 ATM1 get IP:80.229.xxx.xxx
2014.10.24 10:14:50 ATM1 start PPP
2014.10.24 10:14:50 If(ATM1) PPP fail : Peer terminate
2014.10.24 10:14:49 sending ACK to 192.168.1.2
2014.10.24 10:14:48 ATM1 start PPP
2014.10.24 10:07:42 If(ATM1) PPP connection ok !
2014.10.24 10:07:41 ATM1 get IP:46.208.xxx.xxx
2014.10.24 10:07:34 ADSL Media Up !
2014.10.24 10:07:11 ATM1 start PPP
2014.10.24 10:07:11 If(ATM1) PPP fail : Timeout in LCP negotiation
2014.10.24 10:06:21 ATM1 start PPP
2014.10.24 10:06:21 If(ATM1) PPP fail : Timeout in LCP negotiation
2014.10.24 10:05:31 ATM1 start PPP
2014.10.24 10:05:31 If(ATM1) PPP fail : Timeout in LCP negotiation
2014.10.24 10:04:41 ATM1 start PPP
2014.10.24 10:04:41 If(ATM1) PPP fail : Timeout in LCP negotiation
2014.10.24 10:03:53 ATM1 start PPP
2014.10.24 10:03:53 If(ATM1) PPP fail : Timeout in LCP negotiation
2014.10.24 10:03:05 ATM1 start PPP
2014.10.24 10:03:01 ATM1 stop PPP
2014.10.24 10:00:07 If(ATM1) PPP connection ok !
2014.10.24 10:00:06 ATM1 get IP:80.229.xxx.xxx
2014.10.24 10:00:05 ATM1 start PPP
2014.10.24 10:00:01 ATM1 stop PPP [/tt]
Firstly it shows the advice in this forum about how to disconnect safely is wrong. I clicked the Disconnect button and it reconnected within 6s, before I had had time to unplug the line. Once the line was unplugged, you can see it retries every 50s. I am not sure why it disconnected again 7min after successfully reconnecting, but I have included that for completeness.
It seems unlikely that a more modern router would behave differently, although if you have tried two routers from different manufacturers it is also unlikely both would have a similar firmware error. You could try taking one of the routers home to see how it behaves with no telephone line connected.
24-10-2014 10:56 AM
On the TG582 with the 10.2.2.* firmware, if you telnet in to it you can do the following commands:
ppp ifdetach intf=Internet
xdsl config status=down
xdsl config status=up
ppp ifattach intf=Internet
They drop PPPoE, drop sync, raise sync, raise PPPoE. If that resurrects the connection without rebooting the router I'm sure the Pi idea is practical.
24-10-2014 10:59 AM
Quote from: sjptd Even something like a Raspberry Pie should be enough; possibly cheaper than any custom devices.
Apart from making a mess, I'm not sure how anything produced by Mary Berry is going to help!
