Will my Sync return to it's previous level at any point.
- Will my Sync return to it's previous level at any ...
Re: Will my Sync return to it's previous level at any point.
19-06-2014 11:53 AM
21-06-2014 4:10 PM
Before I moved it had raised it up 4mbps in a week. I am dreading what DLM will do on this new line but we will see.
21-06-2014 5:01 PM
21-06-2014 7:05 PM
Yes that is odd. I did reboot once after 72 hours and again before I left. It settled on 65mbps before I pulled the plug.
Well estimates here at the new address are from 47-49 so that's probably 60 down to 50 when DLM decides it wants to ruin things. I have no idea why it kicked in on my old connection. I hope this one is not affected as much. Mind you there are more people on this NGA so it will probably mess things up.
25-06-2014 12:40 PM
can i get a DLM reset after all my sync and profiles wouldn't be this low in the first place if 3 engineers hadn't come to do their tests they may not have found anything but they did cause my Sync and profiles to drop further than the fault had caused, I waited long enough after the fault was fixed for DLM on its own to raise them and it did next to nothing as i say 1Mb in over 10 days, I checked this morning before the power went off and it had still remained at 58Mb so it's not like it was increasing on it's own
25-06-2014 2:07 PM
Sorry to hear this has dropped again, seems like the latest drop would be linked to the work you've had done given the timing of this however recovering 1mb over 10 days is quite good going so based on this as well as the current speed you're getting, it would outweigh the cost and complexity involved with arranging for an engineer to attend the exchange to force a DLM reset on the line.
Understandably you want to get back to the speeds you saw before the initial investigations however the recovery time as been favourable and as such we would need to wait this out and see where the DLM takes it of its own accord at this stage.
25-06-2014 3:05 PM
25-06-2014 3:16 PM
I've mentioned on a number of occasions that sending out engineers isn't going to necessarily mean you're going to get your DLM Reset. There are strict rules surrounding DLM Resets of when they can be done and what instances they can be done. A DLM Reset will only be put through by an engineer if the engineer has had to make a physical change on the network that might affect your sync rate.
The engineer doesn't have to do a DLM Reset but the option is available to them. DLM will increase your speeds if it feels that the line can cope with higher/faster speeds. Your line is monitored by DLM and reports on it every 15 minutes so it's pretty clued up on what changes need to be made, if any at all. I'm sorry that you're unhappy with your speeds, but you're connecting and getting speeds better than your estimate and we don't consider the drop you've had in speeds to be a fault.
I think moving forward, the course of action we will follow, is to allow DLM to make the changes it deems necessary.
25-06-2014 3:30 PM
25-06-2014 3:40 PM
I appreciate you're unhappy given that your speeds have dropped, but there is very little we can do about that I'm afraid, we don't hold any direct control over any external influences on your line or further uptake at your cabinet which is the likely reason. Because your connection worked at a higher rate historically, doesn't mean that speed is going to be maintained, that's why estimates change, as external changes change from time to time.
If you give your line time, I'm not saying it's going to be quick, but if you do give your line time, and leave it to do it's thing, if your line is of good enough quality, the speeds will increase.
25-06-2014 3:54 PM
25-06-2014 4:16 PM
25-06-2014 4:17 PM
25-06-2014 5:16 PM
25-06-2014 5:49 PM
Not paying to be insulted. My experience was fine until DLM messed it up - that's a fact.. and it probably will do again.
Thanks Terra, I appreciate what you said.
