Will a Filtered faceplate help with this?
- Will a Filtered faceplate help with this?
- « Previous
- Next »
Re: Will a Filtered faceplate help with this?
04-12-2009 11:17 PM
no it not the bRAS profile stuck, that's part of the BT system. It looks like it is your PN one that is stuck - Current Line Speed 3500, which is why you are getting throughput speeds just under that.
To be sure can you run the BT speedtester again and do a text copy and paste of the results here. Hopefully then someone from PN looking at the boards will pick it up and deal with it.
Message 31 of 35
(228 Views)
05-12-2009 10:39 AM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed; 3057 Kbps
Max Achievable Speed; 7150 Kbps
Download speed achieved during the test was; 3057 Kbps
For your connection, the acceptable range of speeds is; 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Message 32 of 35
(228 Views)
05-12-2009 7:47 PM
I gave the profile a tickle earlier from our side, try a reboot and another speedtest, you should see better results.
Message 33 of 35
(228 Views)
05-12-2009 8:25 PM
Thanks Chris, that seems to have done the trick
I'm now getting just under 6.5Mb/s, which is excellent!
Download Speed; 5977 Kbps
Download speedachieved during the test was - 5977 Kbps
Thanks again to all who have helped.
Now what am i gonna do to feed my thirst for ever faster speeds?
#Thinks; Ping!
#Thinks; Ping!
Message 34 of 35
(228 Views)
05-12-2009 11:32 PM
@Chris Parr
Thanks for giving this your attention, cheers,
Chris.
Chris.
Message 35 of 35
(228 Views)
- « Previous
- Next »
