Will Plus net be offering faster speeds soon?
tartanjulie
is there anything in the works?
5 REPLIES 5
Re: Will Plus net be offering faster speeds soon?
Have you checked to see
what speeds are available to you using the BT  Broadband Availability Checker  ?
and what Plusnet can provide in the  Offers and upgrades  section of the Members Centre  ?
Plusnet don't acknowledge any new products, features, or speeds, in advance of launch day
tartanjulie
No idea what any of this means
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low      VDSL Range A (Clean)VDSL Range B (Impacted)G.fast Range A (Clean)G.fast Range B (Impacted)
8075.8201969.6AvailableAvailable
8074201967AvailableAvailable
299.1215.84722.9191GreenGreen
253.2184.63316.3168.8GreenGreen
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33050--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability DateWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 17--10 to 19.5Available
Up to 17Up to 1.510 to 19.5Available
Up to 7.5--6.5 to 8Available
2----Available
2----Available
Other Offerings Availability DateVDSL MulticastADSL MulticastG.Fast Multicast
Available
Available
Available
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
tartanjulie
and this is the max speed that plus net can offer me
Unlimited Fibre Extra
68 - 72Mb
estimated download speed£24.99
tried this at another address also still same speed so I assume this is the max offered
Fixes: 86
@tartanjulie
You appear to be able to get faster speeds, but not from PlusNet.
The data you posted shows two products - FTTC and g.Fast (a version of FTTC).
Unfortunately for you PN doesn't offer g.Fast products and I suspect they have no plans to do so (though you never know). You'd need to move to an ISP who does offer g.Fast at the end of your contract. You might be able to move to BT sooner if PN agree to waive early termination charges but you'd need to speak to a staff member first.
I'd recommend looking at  Pulse8 G-Fast  (then click on the G-Fast tab at the top of the table)
                      "P8G.Fast Home"  = 160Mbps/30Mbps  for £48/month
        "P8G.Fast Ultimate Home"  = 330Mbps/50Mbps  for £57/month
