Will Plus net be offering faster speeds soon?
- Re: Will Plus net be offering faster speeds soon?
29-08-2022 5:17 PM
is there anything in the works?
29-08-2022 5:54 PM - edited 29-08-2022 5:59 PM
Have you checked to see
what speeds are available to you using the BT Broadband Availability Checker ?
and what Plusnet can provide in the Offers and upgrades section of the Members Centre ?
Plusnet don't acknowledge any new products, features, or speeds, in advance of launch day
29-08-2022 6:06 PM
No idea what any of this means
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low VDSL Range A (Clean)VDSL Range B (Impacted)G.fast Range A (Clean)G.fast Range B (Impacted)
| 80 | 75.8 | 20 | 19 | 69.6 | Available | Available |
| 80 | 74 | 20 | 19 | 67 | Available | Available |
| 299.1 | 215.8 | 47 | 22.9 | 191 | Green | Green |
| 253.2 | 184.6 | 33 | 16.3 | 168.8 | Green | Green |
| 330 | 50 | -- | Available | -- |
| Up to 17 | -- | 10 to 19.5 | Available |
| Up to 17 | Up to 1.5 | 10 to 19.5 | Available |
| Up to 7.5 | -- | 6.5 to 8 | Available |
| 2 | -- | -- | Available |
| Available |
| Available |
| Available |
| N |
| N |
| Y |
29-08-2022 6:10 PM
and this is the max speed that plus net can offer me
Unlimited Fibre Extra
tried this at another address also still same speed so I assume this is the max offered
29-08-2022 6:24 PM
You appear to be able to get faster speeds, but not from PlusNet.
The data you posted shows two products - FTTC and g.Fast (a version of FTTC).
Unfortunately for you PN doesn't offer g.Fast products and I suspect they have no plans to do so (though you never know). You'd need to move to an ISP who does offer g.Fast at the end of your contract. You might be able to move to BT sooner if PN agree to waive early termination charges but you'd need to speak to a staff member first.
29-08-2022 7:07 PM
I'd recommend looking at Pulse8 G-Fast (then click on the G-Fast tab at the top of the table)
"P8G.Fast Home" = 160Mbps/30Mbps for £48/month
"P8G.Fast Ultimate Home" = 330Mbps/50Mbps for £57/month
