Will Interleaving Work For Me?
- Will Interleaving Work For Me?
16-05-2009 9:32 AM
My connection has deteriorated badly ovet the past week. Firstly, i noticed it dropping out - and now (suddenly) the speed is down to 130kbps. I regularly use the VPN facility (to connect to the office at work), so I think I realised quite quickly that there was a problem. Obviously, the VPN is unusable at the moment.
I removed the faceplate on the master socket and my router and microfilter are plugged in directly. There are no other items of equipment plugged in at all. Still no improvement at all.
I am using my wireless laptop - my desktop Desktop and NAS are no longer connected to the router.
PlusNet Technical Support has asked their wholesaler to turn on "interleaving" for my connection. Will this have such a dramatic effect in my case? Is it more that there is a technical fault of some description. In any case, it seems that the interleaving could take up to a week to take effect. What can I do in the meantime?
If anyone can offer any advice, it would be much appreciated.
TIA,
Stephen
BTW, I know we had thunderstorms yesterday (that HAS been known to affect my connection), but the problem precedes this.
Re: Will Interleaving Work For Me?
16-05-2009 1:22 PM
16-05-2009 2:46 PM
These are the current stats. The connnection has been up for just over 2 hours.
ADSL Firmware Version 3.02.06.00
Modem Status Connected
DownStream Connection Speed 768 kbps
UpStream Connection Speed 96 kbps
VPI 0
VCI 38
ADSL Link Downstream Upstream
Connection Speed 768 kbps 96 kbps
Line Attenuation 51 db 15.5 db
Noise Margin 11 db 6 db
Thanks,
Stephen
adie:quote
16-05-2009 3:20 PM
16-05-2009 5:56 PM
I tried what you suggested, but I have since lost my telephone dialling tone completely (I DID plug my phone back in BTW).
BT is sending out an engineer on Monday to take a look.
However, my Broadband is STILL limping along in the meantime. Very Odd....
Stephen
adie:quote
16-05-2009 6:32 PM
Quote from: Studio_Two but I have since lost my telephone dialling tone completely
That is good news - lets hope it stays like that until the engineer arrives. Solid faults are always quicker solved than intermittent faults which can go on for months!
16-05-2009 8:02 PM
20-05-2009 7:25 PM
BT finally reconnected my telephone line earlier today.
The broadband speed is still horrendously slow.
Could you tell me if the router stats are any better than before?
DownStream Connection Speed 4704 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
Connection Speed 4704 kbps 448 kbps
Line Attenuation 43 db 13.5 db
Noise Margin 10 db 22 db
Will it just be a matter of waiting for things to settle down a bit? Then, there is this "interleaving" thing that PlusNet has turned on..
Thanks,
Stephen
20-05-2009 7:33 PM
Quote from: Studio_Two Connection Speed 768 kbps 96 kbps
Quote from: Studio_Two ADSL Link Downstream Upstream
Both downstream and upstream speeds have increased and your attenuation has dropped.
It should speed up quite quickly (12-24 hours) with speed increases like that.
20-05-2009 8:01 PM
Thank you very much indeed to everyone that helped me out.
21-05-2009 3:00 AM
You need to leave your modem/router on 24/7 for your profile to increase at the quickest rate. What time did you switch it on before the last set of stats that you posted?
I'd suggest that either switch it on or resync in the morning, between 8 a.m and midday may be best, and grab a set of stats immediately after the resync and post them.
21-05-2009 10:21 AM
@Studio_Two
I've amended your profile at this end to match BTs @ 4000Kbps. Try rebooting your router and hopefully you should see a good improvement in speed.
