Will I see different sync rates on my router?
- Will I see different sync rates on my router?
30-03-2009 3:21 PM
Hi all,
I'm on the waiting list for this trial, my exchange (Ramsgate, NDRAM) is due for upgrade tomorrow according to SamKnows. My question is, will I see higher sync rates on my router when the exchange is upgraded & before PlusNET's done anything? I understand I won't get those higher speeds until PlusNET have acted, but just wanted to know if I'd get any clues to the upgrade having happened.
Thanks for looking.
Thanks for looking.
Message 1 of 7
(1,427 Views)
6 REPLIES 6
Re: Will I see different sync rates on my router?
30-03-2009 3:24 PM
Hi Cloudmaster.
You won't see different sync speeds until the order has actually been completed.
Message 2 of 7
(569 Views)
30-03-2009 3:27 PM
Thanks for the quick answer James, I suppose my next question then is how will anyone know the exchange has been upgraded, will BTW tell you?
Message 3 of 7
(569 Views)
30-03-2009 3:28 PM
We will know
But please bear in mind that because we're placing orders manually and it's a trial (ie: we're placing a limited number of orders each week) there's normally a delay of about 2-4 weeks.
Message 4 of 7
(569 Views)
30-03-2009 3:30 PM
Thanks again for your quick answer James. I realise there's probably a lot of exchanges due for upgrade at the same time. I'll just sit back & wait, it'll happen when it happens
Message 5 of 7
(569 Views)
30-03-2009 3:45 PM
Quote from: Cloudmaster I realise there's probably a lot of exchanges due for upgrade at the same time.
Sam Knows lists quite a few exchanges that are due to be upgraded by 31/3/09. My exchange (Cheltenham) is one example, although the Plusnet exchange checker says there are no plans for 21CN WBC. What does Plusnet know that Sam doesn't?
My other car isn't a Ferrari
Message 6 of 7
(569 Views)
30-03-2009 4:32 PM
Looks like mine's still on track
WBC Rollout Status
BT have announced a ready for service date for this exchange. The estimated go live date is between 31st March 2009 and 31st March 2009.
This was last updated 9th March 2009
WBC Rollout Status
Message 7 of 7
(569 Views)
