Will I benefit from moving away from Plusnet?
- Will I benefit from moving away from Plusnet?
24-08-2009 10:14 AM
Re: Will I benefit from moving away from Plusnet?
24-08-2009 10:18 AM
To get a better idea of your line status can you post speeds, attenuation and noise margin from your router (this link explains how to get them http://www.kitz.co.uk/adsl/frogstats.php )
24-08-2009 10:20 AM
Like you say, unfortunately we have no information on the ADSL2+ upgrade on your exchange yet.
Like Jim says, it might be an idea to post your line stats, but given your distance from the exchange, I wouldn't expect much of an improvement from ADSL2/ADSL2+.
24-08-2009 10:28 AM
24-08-2009 10:46 AM
Down: SNR Margin 9.4 db Line Attenuation 60.2 db
Up 19.0 db 31.5 db
The ADSL is shewing 3136
mybroadbandspeed tester is showing 2298/377 Kbps
BT have me at 2500 Kbps
24-08-2009 10:49 AM
The point to make is that to get a better effective speed your sync rate would need to increase to over 3424 kbps and you are unlikely to achieve that
24-08-2009 11:19 AM
24-08-2009 1:01 PM
Are you saying you think my line looks OK? If so why I am not getting the 4Mbs on the graph - think a mate a few hundred yards from me gets that speed as well?
Jelv:
There is also Rutland Telecom, who have ADSL2+
24-08-2009 1:04 PM
You need to look at the attenuation figure which is directly related to line length and assumed a default noise margin of 6dB and perfect conditions.
Looking at the graph and putting in your attenuation I get just under 3000kbps
24-08-2009 1:06 PM
http://www.kitz.co.uk/adsl/max_speed_calc.php will give you the expected speeds if you enter the attenuation.
Are you using the master socket or an extension? If you are using an extension it would be worth checking if the router stats look better if you plug direct in to the test socket.
24-08-2009 1:08 PM
24-08-2009 11:30 PM
25-08-2009 12:02 AM
