Wifi working for all devices except one
ericjhanvey
Neither wifi or router (directly with ethernet) will give me a connection for one laptop in the house.  All the others are working fine.  It appears to connect but then falls out.  Any ideas, my partner needs it for work.
Eric
1 REPLY 1
MauriceC
Fixes: 17
Re: Wifi working for all devices except one
Most likely cause is a problem with the Network card or Device driver software on that laptop.
Troubleshooting help will depend on the Laptop H/W and Operating system in use?
