Wifi password
- Re: Wifi password
Wifi password
22-03-2012 12:30 AM
At first I needed tu log in to my wifi network with a password. Now I don't, andI haven't changed any settings. I'm worried anyone could be using my network now. What can I do?
Message 1 of 5
(1,321 Views)
4 REPLIES 4
Re: Wifi password
22-03-2012 12:44 AM
What device are you using? It may well have saved the password for you.
That's RPM to you!!
Message 2 of 5
(684 Views)
Re: Wifi password
22-03-2012 12:46 AM
Either the device you are connecting has remembered the password or the password has been removed from the router.
Log into the router's configuration screen and check the WiFi set-up.
Edit: I've been beaten to it
Message 3 of 5
(684 Views)
Re: Wifi password
22-03-2012 5:21 PM
Maybe yours is a 585 v8 like mine. It keeps the same password no problem but every time you turn on wifi you get three options down the bottom.
Disabled
Use WEP Encryption
Use WPA-PSK Encryption
As you've probably guessed it always defaults to disabled. So you have to remember to select the one that suits you.
Disabled
Use WEP Encryption
Message 4 of 5
(684 Views)
Re: Wifi password
22-03-2012 5:26 PM
Message 5 of 5
(684 Views)
