Wifi not connecting to Mobile and 1 laptop
Legend
Fixes: 258
Re: Wifi not connecting to Mobile and 1 laptop
@caio Thanks for that - the good news is there doesn't appear to be any issue on there. As you have a working machine, my next guess is that the non-connecting devices have got their internals in a twist. For the phones; tell them to 'forget' the connection, power them down completely, leave off for a good 25-30 minutes, and then restart/reconnect them.
The same might work for the laptop. Ignore that - forgot it was switched off!Embarrassed
Mustrum
Fixes: 77
@jab1  Hi John, as the OP is on 263 firmware that would be my first suspicion.
caio
Thank you @jab1 I will do that and come back tomorrow with an update then!
Once again appreciate the help!
Legend
Fixes: 258
@Mustrum Ooops - missed that, but if they had been connected previously?..
@caio Suggest you post a request here:https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363#M15510 for an update.
caio
Hi @Mustrum @jab1  no problem, I will post this issue on that thread as well!
caio
Morning @jab1 @Mustrum
Just a quick update : all devices are now connecting to the wifi somehow...so everything is back to normal for the time being.
Not sure how but anyway, thank you for the help !!
Have a nice day !
Legend
Fixes: 258
Good to hear, @caio . Electronic devices seem to have minds of their own - that sometimes fail. 😀
