Wifi keeps dropping south Manchester
bigbird61
Hi anyone experiencing internet droppage in South Manchester in last few days?
4 REPLIES 4
Fixes: 306
Re: Wifi keeps dropping south Manchester
@bigbird61 What kind of 'droppage'? Which Hub/router do you have, and how do the lights behave when the problem occurs?
willcutforth
Fixes: 113
@bigbird61 I am seeing lots of drops from our side. It can be seen here. There's definitely an issue but I want to ask if anything has changed recently? Can you also attach some pictures of the master socket and where the router is located?
 Will Cutforth
bigbird61
yes I will thanks. Nothing has changed recently in terms of my set up, other than the fact I'm out of contract and about to be put on the default one. I'll get some screen shots as you suggest. thanks
ClaudiaG23
Fixes: 25
@bigbird61  I've added a ticket to your account to get an engineer booked for you. Please can you reply to the ticket her https://www.plus.net/wizard/?p=view_question&id=236786916
 Claudia Garner
