Wifi down, red light on router
jackwinkles
Hi, we got in today at 13:00 and there was a red light flashing on the router. We restarted and now it is a constant red light. We restarted 90 mins after the problem was discovered and the issue is still happening. Could you please advise?
5 REPLIES 5
Legend
Fixes: 288
Re: Wifi down, red light on router
@jackwinkles Is your phone line clear? Please follow the below:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
jackwinkles
Unfortunately we don't have a landline phone to try
Legend
Fixes: 288
OK - just use the BROADBAND link and report your problem. A cheap corded handset is a useful tool whilst you are on ADSL/FTTC , though.
Fixes: 430
@jackwinkles
Try pushing a paperclip in the hub reset hole, hold the switch closed for 25 seconds or so. Wait 10 minutes or so to see if it recovers. If you still have a red light then your hub has probably developed a fault and needs replacing.
jackwinkles
Thanks for your help mate 👍
