Wifi blocked on mobile apps ?
lauritelli2211
Hello !
For the past 2 days I've been struggling with an issue - my wifi keeps blocking phone apps ? The only app I can actually use is instagram. I have turned off the safeguard option, as well as gone through the list of blocked sites and everything seems to be right.
I did try to reach out to plusnet about this issue, buy they just sent me a bunch of articles that haven't helped.
So far I've restarted, re-booted and turned off my router, but nothing seems to change. I did think it was my phones fault, but finds out that 3 phones have lost any kind of access to mobile apps (all androids).
If anyone has ran across this issue or has any ideas/suggestions on what should I do next, that'd be very appreciated.
Thank you !
Tags (4)
