Wifi Dropped repeatedly
- Wifi Dropped repeatedly
11-08-2012 11:27 PM
Infuriatingly my Thomson TG585 v8 router keeps disappearing(dropping) and reappearing from my available wifi networks list on my MAC after working for the past two years fantastically.
When the signal is there it is strong.
Connected by LAN it works fine,but this is not possible logisticaly.
This has been going on for a few weeks now.
I see a few others in the forums have had this problem but no answer is given.
Every page or two fails to load.
Imagine trying to log into your bank account 10 times as you are sent back to the previous page as it hasn't been accepted.
This has possibly coincided with the recent appearance of a BT Fon network in my area although I have blocked the MAC from joining this, it does appear in 'available' networks but never 'joins' it.
What is the answer?
I enjoy being a Plusnet customer and support is excellent but this is no fun.
Thanks in advance,Iwan
Re: Wifi Dropped repeatedly
12-08-2012 6:51 AM
12-08-2012 8:23 AM
If conflicts with neighbouring router, then adjust your routers channel.
12-08-2012 10:49 AM
This is where you can find SSID
There seems to be some issues with the latest version download today, if that fails then try the previous version
My advice is to literally sit and run it for a week and when your wifi drops you may notice something appear on the log. Better to have it running all the time than try and see something after it happens. Even now mine is working fine I periodically use the SSID app to check that nothing in the area near me could cause me issues.
If you get stuck just shout and I am sure we can all help you with this tool.
13-08-2012 11:33 AM
Thanks for your replies.
Just to remind you,this problem is occurring on my MAC and is just as bad on my Windows laptop.
ReedsRichard - I am runnning firmware 8.2.7.8 and was recently give a new router as it was easier than upgrading the software(supplied by Plusnet).
BRABUS - Thanks for your reply.I have iStumbler which tells me whats running on what frequency.I have tried many different frequencies over a period of weeks.BT for example are running on 11.I am running on 1 today but narrow bandwidth means today is difficult.
Please keep suggestions coming.
Thanks,Iwan
13-08-2012 6:15 PM
13-08-2012 7:52 PM
13-08-2012 8:42 PM
13-08-2012 9:13 PM
31-08-2012 11:31 PM
03-09-2012 10:24 AM
Quote and was recently give a new router as it was easier than upgrading the software
Which router are you using at the moment, the last I can see from your account is that we replaced it last year, I'm just wondering if we replaced it with the same model or maybe a TG582n?
03-09-2012 12:33 PM
Thanks,Iwan
04-09-2012 10:07 AM
