Wierd BT speedtest result
rongtw
Fixes: 12
this morning i had problems with BT speed-test giving error , so i try  just now but i got this  Crazy
But speedtest.net says its ok apart from a higher  ping than usual
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Wierd BT speedtest result
Hi rongtw,
There are some issues with the BT Speedtester at the moment. We seem to be getting quite a few people that are getting quite sporadic results from it. You can see more information and responses regarding this issue here: http://community.plus.net/forum/index.php/topic,103179.0.html
Chris Pettitt
Cloud Environments Engineer
rongtw
Fixes: 12
well it seams to be working again this morning  Wink
