WiFi is running too slow
Jayden
my WiFi is on fibre WiFi, I’ve done a speed test and I’m getting under 1mb a second and it’s been like this for weeks, I can’t even open chrome and when I do it’s taking nearly 3 minutes.
18 REPLIES 18
Legend
Fixes: 260
Re: WiFi is running too slow
@Jayden
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Jayden
When I dial that number it says this number isn’t recognised
Legend
Fixes: 260
What - 17070 ?
Jayden
Well we don’t have a corded phone
Legend
Fixes: 260
Do you have a landline phone at all - it certainly won't work  from a mobile.😉
Jayden
I’m putting the number in correctly just saying the number isn’t recognised
Legend
Fixes: 260
On a landline phone? And you are with Plusnet?
Jayden
Yep we’re with plusnet, we don’t have any landline phones
Legend
Fixes: 260
OK. I can't understand why 17070 doesn't work then - it should work for any connection using the BT network. Can you hear any noise on the phone once you lift it/press the 'dial' button?
 EDIT: So - no landline handset - can you borrow phone from anyone?
Jayden
When I call it says ‘this number isn’t recognised, please check and dial again’ twice then makes like a beeping noise afterwards continuously
Legend
Fixes: 260
It will do -it is only available on phones connected to the BT network, not mobiles.
Give me five minutes to think of another approach.
Just so I know how to reply, how much computer/technical knowledge do you have? - not being cheeky, but it helps me to know what questions to ask.
Jayden
I’m decently well educated on computer side
Legend
Fixes: 260
OK - five minutes.
Legend
Fixes: 260
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
