Wi-Fi problems with 582n and Apple iPad / iPod Touch
- Wi-Fi problems with 582n and Apple iPad / iPod Tou...
13-05-2013 9:45 PM
I have recently upgraded my router to a TG582n. I used to have a TG585. I am having problems with the wi-fi on the new router, particularly whilst it is talking to an iPad 4 and an iPod Touch (3rd gen), although our Dell Inspiron, PS3 and Kindle are not exactly happy either. The signal strength is good, but the authentication keeps failing. The Event Logs simply say "can't get authorized", which is not helpful.
Are there any stats pages I can look at?
I have FW version 8.4.4.J. Is there a more recent version that might help?
Thanks,
Thanks,
Message 1 of 5
(1,020 Views)
4 REPLIES 4
Re: Wi-Fi problems with 582n and Apple iPad / iPod Touch
28-05-2013 2:32 PM
Welcome to our community forums.
Apologies for the delayed reposnse, you can upgrade your router firmware at http://products.plus-payh.co.uk/firmware/
Let me know if that helps.
Message 2 of 5
(468 Views)
04-06-2013 8:32 PM
Hi Chris,
The upgrade solved the problem. The Wi-Fi is now much more reliable and much, much faster.
Thanks,
Thanks,
Message 3 of 5
(468 Views)
05-06-2013 8:45 AM
Chris,
Does your response imply that 10.2.2.B is now approved for general use?
Thanks,
Kevin
Thanks,
Kevin
Message 4 of 5
(468 Views)
05-06-2013 11:32 AM
That's correct
Message 5 of 5
(468 Views)
