Wi Fi Streaming ~ How to Improve?
- Re: Wi Fi Streaming ~ How to Improve?
01-02-2013 8:13 PM
I am on Plusnet Fibre, using the router supplied by Plusnet Fibre Broadband; i.e. Netgear WNR 1000 V3
My PC is a different room from the router.
I stream media wirelessly within my house using Windows Media Player and via the router, but occasionally streaming stalls and can be difficult to restart. I wonder whether this is because my WiFi signal is attenuated by the internal walls or interference from other WiFi in my neighbourhood. I have done what I can to ensure that my WiFi signal is maximised according to Plusnet Support Pages and have even tried a range extender.
I have looked at the other nearby WiFi signals, using inSSIDer or Meraki. Most of the time my WiFi is a lot stronger within my premises than other nearby signals. However, there are times when they suddenly peak and for brief periods appear stronger than my own. However, I have been unable to definitely link breaks in my streaming to when these other signals peak. Usually inSSIDer shows my PC to router signal between -50 to -60 dBm amplitude. According to Meraki it is about 90%. I don't whether these measurements indicate a strong signal?
However, I see that Netgear produce other routers which appear to offer better performance that the WNR 1000 V3. Would it be a possibility for me to invest in a more powerful router to give me more reliable WiFI.
Any advice appreciated. Thanks.
Message 1 of 7
(2,247 Views)
6 REPLIES 6
01-02-2013 8:15 PM
Have you considered homeplugs like these for example?
Message 2 of 7
(568 Views)
01-02-2013 8:17 PM
Try use a different wifi channel to the ones your neighbours are using, inssider shows you which they are on
FTTP 500 regrade from Tues 28th November
Message 3 of 7
(568 Views)
01-02-2013 8:51 PM
Thanks for suggestions.
Channel 6 seems to be the most popular one around here. I have tried using empty channels but not 100% successful results. Since then I have managed to improve my signal a bit, but maybe Power Line Transmission as suggested, would resolve the issue completely?
Message 4 of 7
(568 Views)
01-02-2013 9:20 PM
Either use the plugs or invest in a decent router with a 5Ghz channel as well as the 2.4 Ghz on your PN router. My ASUS RT-N56U has vastly improved my wireless experience.
Message 5 of 7
(568 Views)
04-02-2013 11:09 AM
Channels 6 or 11 tend to be the best, however I'd advise using inSSIDer to find the best one: http://www.metageek.net/products/inssider/
Message 6 of 7
(568 Views)
07-02-2013 9:16 AM
Thank you for advice and comments about my WiFi streaming problem. I have been using inSSIDer and Meraki, to monitor local activity. I have tried switching channels. Unfortunately, although my WiFi streaming from Windows Media Player to my Panasonic Blu-Ray Player runs very well most of the time, it is still "stalls" from time to time, particularly during the evenings. By "stalling" I mean stops altogether, not just a bit of buffering. Can be restarted only by a reboot of the streaming PC.
I have tried a Netgear WR3500RP Extender, but with indifferent results. I think that my home is the wrong layout to get much benefit from an extender.
So I am focussing on a new router: ASUS RT-66NU, often discussed in these forums. I have also thought about a Netgear N900, because my Plusnet fibre is currrently delivered through a Netgear N150 (supplied by Plusnet).
I wonder if anyone has an opinion regarding which is best between these routers?
Message 7 of 7
(568 Views)
