Wi Fi Hangs but Ethernet fine
- Wi Fi Hangs but Ethernet fine
27-11-2011 9:56 PM
Re: Wi Fi Hangs but Ethernet fine
28-11-2011 6:32 AM
28-11-2011 8:09 AM
28-11-2011 8:27 AM
are you able to use the web browser to access your router's configuration web pages ?
The answer will narrow down whether you have a wireless connection problem, or an internet connectivity problem.
28-11-2011 10:41 AM
28-11-2011 11:09 AM
28-11-2011 11:38 AM
28-11-2011 1:07 PM
Have you tried changing wireless channels on YOUR router to another clear channel number, to see if that cures it ?.
The other old chestnut is if there is some problem with DHCP, and possibly timing out the lease on your wireless connections.
You could try setting the laptop to be a static IP address outside your router's DHCP address range.
You could also try setting the laptop DNS settings to "208.67.222.222" and "8.8.8.8" to see if the problem is router DNS related - which is not unknown !
28-11-2011 1:27 PM
01-12-2011 1:10 PM
