Why is plusnet restricting my speed?
harwin
Router stats:
                Downstream Upstream
Rate (Kbps): 16967 kbps 443 kbps
SNR Margin (dB):  6.0             23.4
Attenuation (dB):   22.0     10.9
BT speedtest:
IP profile: 14654kbps
Download speed: 470kbps
Upload speed: 370kbps
With BT router username:
Download speed: 12957kbps
Upload speed: 349kbps
I have had recent connection problems but they are sorted now, the download speeds were much faster with BT router username,
if BT have raised my download speed why haven't plus net followed suit?
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Why is plusnet restricting my speed?
It looks as though your IP profile had dropped down to 500 at some point over the last few days and then increased back to 14654. Our system hadn't received a report saying that it needed to move back to the higher profile yet.
I've made the change manually so within the next few minutes you should see your speed get back to normal.
 Chris Parr
 Plusnet Staff
harwin
I'm getting speeds of about 9000kbps now which I'm more than happy with, thanks for your help!
