Why is my maximum achievable speed now only 4 Mbps?
- Re: Why is my maximum achievable speed now only 4 ...
01-09-2013 8:05 PM
Max Achievable Speed: 4 Mbps
Download speed achieved during the test was - 3.67 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 3.8 Mbps
Upload speed achieved during the test was - 0.75Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Re: Why is my maximum achievable speed now only 4 Mbps?
01-09-2013 8:55 PM
We need the line stats from your router to see if the speed you're getting is the best possible or not. For longer lines, ADSL2+ may provide little or no increase in speed, and you probably won't even have been switched to ADSL2+ anyway. So your exchange having been upgraded won't necessarily increase your speed.
01-09-2013 10:05 PM
Uptime: 26 days, 18:08:20
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 984 / 3,492
Bandwidth (Up/Down) [kbps/kbps]: 939 / 4,312
Data Transferred (Sent/Received) [MB/GB]: 480.07 / 7.10
Output Power (Up/Down) [dBm]: 12.5 / 18.5
Line Attenuation (Up/Down) [dB]: 27.0 / 47.0
SN Margin (Up/Down) [dB]: 7.0 / 2.5
Loss of Signal (Local/Remote): 327,677 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 857,225 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 4,161 / 298,671
HEC Errors (Up/Down): 5,236 / 1,062,166
01-09-2013 10:58 PM
02-09-2013 12:26 AM
Max Achievable Speed: 7.15 Mbps
Download speed achieved during the test was - 2.9 Mbps
For your connection, the acceptable range of speeds is 600 Kbps-7.15 Mbps.
IP Profile for your line is - 3.5 Mbps
Your DSL Connection Rate: 4.42 Mbps (downstream) 448 Kbps (upstream)
02-09-2013 7:25 AM
The "1.2 Mbps-4 Mbps" is determined by your line speed. It does not control or restrict your line speed to a max of 4 Mbps. If you managed to improve your setup or wiring and got a higher speed, the BT speedtester would show a higher range of speeds.
02-09-2013 5:00 PM
02-09-2013 7:32 PM
If your master socket is the NTE5 type (see the wiring link provided by ejs) plugging your router via a filter into the test socket shown there should eliminate internal wiring effects. If you can do that posting the router stats (DSL Connection information) like those you posted earlier would help to show if the problem is internal or external. (Speedtests won't react quickly enough.)
When moving the router it's best to use the router's web interface to disconnect from Plusnet first; this should stop the DLM at the exchange thinking the disconnection might be a fault.
02-09-2013 9:14 PM
03-09-2013 12:04 AM
03-09-2013 11:19 AM
03-09-2013 11:40 AM
03-09-2013 1:48 PM
Quote from: w23 Is your extension cable a flat type?
Yes it is but the new one I bought (suggested by Anotherone from ADSLnation in the other thread mentioned above) is a twisted pair so I really must change them over.
03-09-2013 6:48 PM
